Rotors - Did something stupid.
Old Sep 6, 2010 | 06:05 PM
ringnalda506's Avatar
ringnalda506
Originally Posted by kastoria
Hey guys the other day I replaced my front shocks, wheel hubs, rotors and pads. Lots of work getting those wheel hubs loose, took a better part of the day. So finally after shear heat exaustion I finally get the front end to the point where its just a simple rotor and pad job. I bought power stop cryo rotors and hawk ceramic pads - Love 'em!
Apparently Power Stop Cryo rotors are a LEFT and a RIGHT side. Well didnt find that out (cuz I started to rush when the job got easier) until everything was buttoned up and ready to go. I called power stop and they said as long as both rotors are rotating in the same direction its not really a problem - which after driving it for 2 days they stop on a dime...no shimmy or pull or weird pulse. They said if I put on a LEFT and LEFT or a RIGHT and RIGHT then one tire would be rotating oposite of the other which would be bad.
Now I dont have time to swap the rotors back to their proper sides cuz leaving on a road trip in 1 day and have to work. So my question is if I wait to replace my pads next year (which I generally do new pads once a year regardless of how much is left) can I flip the rotors around at that time without any problem? also Ive never had to cut my rotors once I started doing the pads every year, there was never any type of bad wear or damage cuz it never got to that point.
Thanks
My advice would be to not take any risks and do the swap(before you leave on the roadtrip) The second time around is always a lot faster than the original install
Shouldn,t take you more then 1.5 hours in all
