Electric Window Question
Old Aug 3, 2010 | 05:39 PM
cobytur's Avatar
cobytur
Default Electric Window Question
I got off the phone with my wife yesterday. And she said that the windows in my truck aren't working. She said that you can roll all the windows down from th driver side, but the switches on each door won't roll down that window, like its on lock or something. Anybody have any idea what could cause this? Thank you in advance.
Old Aug 3, 2010 | 06:06 PM
brettj2408's Avatar
brettj2408
the window lock is on.
Old Aug 3, 2010 | 06:17 PM
cobytur's Avatar
cobytur
It still does it after the lock is off.
Old Aug 3, 2010 | 06:23 PM
brettj2408's Avatar
brettj2408
my guess is the contacts for lock came out in the terminal or are loose or the switch part is broken.
Old Aug 3, 2010 | 08:56 PM
luckydt's Avatar
luckydt
Check for broken wires in the wiring that goes through the rubber boot on the door. As stated before pull the switches out, disconnect the connector, blow it out with an air duster, get some diaelectric grease and put it on the the pins. Also check for blown fuses. All of the above are common if you do a search this is a common issue.
Old Aug 3, 2010 | 10:48 PM
gordie580's Avatar
gordie580
Default samw problem
My truck is doing the same thing. The only way to roll down the winds is from the driver side. I pulled out al lthe switches and connectors. I still haven't been able to find the problem... I think I am going to have ot take it in. I tore the door apart and it is lined with plastic and caulk.
Old Aug 4, 2010 | 04:26 PM
Calvert's Avatar
Calvert
I have the same issue in my 03, just havent really had the time or people riding in my truck to mess with it. Im in AZ in the summer so the windows are rarely down this time of year anyways. I know that when i pushed the lock button really hard or even punch they will work again momentarily then stop again...i pulled the switch out and everything is still connected with no broken wires....anyone got some ideas?
Old Aug 4, 2010 | 05:18 PM
meecrob28's Avatar
meecrob28
I had that problem with my '02 and it ended up being the wiring that goes thru the boot of the rear driver's side door. I replaced the broken and brittle wires and not a problem since. Definitely check the boot wiring in ALL your doors before you spend money taking it in......
Old Aug 4, 2010 | 11:13 PM
gordie580's Avatar
gordie580
Default fixed
Well, I today it decided a good old anger fix. I hit the door really hard on the driver side by the window lock switch. And now all the windows work. If I use to lock switch i have to hit it to get all the windows to work.
So I think it is my lock switch not working properly.
