Brake Vibration
Old Aug 4, 2010 | 01:34 PM
Psheff's Avatar
Psheff
Default Brake Vibration
I have a 03 QC with the 4.7 engine, Question when I apply brakes the front end shakes, when I install new rotors and new brakes it stops. After about 500 miles it starts again. I put some sloted and drilled disk with some good pads and same thing. Does anyboday have any ideas on how to fix.
Old Aug 4, 2010 | 01:36 PM
Marx's Avatar
Marx
might have a sticky/stuck/damaged cailper
does it also pull to one side during braking?
Old Aug 4, 2010 | 01:40 PM
Psheff's Avatar
Psheff
No it stops in a straight line. Does not pull
Old Aug 4, 2010 | 02:53 PM
Fav40's Avatar
Fav40
I've gotten a shake a few times too, but otherwise (as in the last 15k miles) it's smooth as glass. Weird ?
Old Aug 4, 2010 | 03:02 PM
dirtydog's Avatar
dirtydog
Moderate User
It's probably your rear rotors that are warped. Pulsating can happen from the rear rotors as well. There was another guy on here that complained about the same thing and I suggested that he should replace the rears because that was likely the culprit. He changed the rears and no more shake.
Old Aug 4, 2010 | 03:22 PM
Psheff's Avatar
Psheff
I will try that, replacing the rear rotors and pads, I will let you know what happens
Old Aug 4, 2010 | 04:06 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, sounds like typical rotors to me also
Old Aug 11, 2010 | 03:18 PM
wolf22m's Avatar
wolf22m
Let me know how it works out. I have the same year and same problem exactly. Haven't touched the rotors yet. Looking for upgrades
