'04 Overheated Transmission - Should I Change Fluids?
Old Aug 5, 2010 | 11:23 AM
k5avj's Avatar
k5avj
Default '04 Overheated Transmission - Should I Change Fluids?
We are driving an '04 Dodge 2500 Ram Diesel & pulling a 5th wheel up to Glorieta, NM from Abilene, TX, I overheated the transmission on the final mountainous pull into our destination. I was pushing it hard during the final 8 mile climb & I believe that is what caused the situation. I did have "tow/haul" engaged.
When I arrived, I noticed by the odor that I had overheated the transmission. I do not have any extra gauges on this truck. (A project to add a transmission gauge for sure when I return home).
1) The transmission is still shifting okay at this point. Should I take it into Santa Fe & get the fluid & filter changed before returning home???
2) Do I need to have "tow/haul" engaged at all times when pulling my 9500# 5th wheel?
3) Do I need to limit my speed when towing my trailer to something less than 70 MPH?
Lynn
(enjoying the cool temps in the mountains of NM)
Old Aug 5, 2010 | 11:59 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Changing wont hurt. I say do it. Chang the filters to if you got the funds
Old Aug 5, 2010 | 12:05 PM
HammerZ71's Avatar
HammerZ71
Without question! Any time you overheat a lubricating fluid it losses it's protective properties in proportion to how long and how hot.
Old Aug 5, 2010 | 01:29 PM
dirtydog's Avatar
dirtydog
Moderate User
I would with out a doubt get a fluid flush. ATF+4..btw..
I would also add a better trans cooler to replace the tiny stock one.
If you continue to drive on burnt fluid, your trans will get hotter faster and burn up pretty quick.
I would keep Tow/Haul engaged when pulling that weight YES.
Old Aug 5, 2010 | 01:33 PM
Marx's Avatar
Marx
yes
yes
and yes
Old Aug 6, 2010 | 12:16 AM
oneHEMI57's Avatar
oneHEMI57
Drive in the climbing lane and keep it out of cruse-control. Let your speed swing from 70 to 20 when running down and over the peak tops. Shift to 'N' every time you come to a in-traffic stop, always with or w/o the trailer.
You have boiled the juice and x4, chg it now! Get the BG treatment w/synthetics.
As suggested, install a aux tranny cooler even if you need to lay it horz with fan under the right floor. Enjoy the country.
Old Aug 6, 2010 | 10:15 PM
k5avj's Avatar
k5avj
Hey guys...thanks for the suggestions. We're on vacation in NM but I'm going into Santa Fe tomorrow to the Jiffy Lube and have the transmission fluid & filter changed.
Old Feb 22, 2011 | 11:16 PM
oneHEMI57's Avatar
oneHEMI57
k5avj, How is that tranny doing since you refreshed the fluid last Aug? Has the heating problem reoccurred?
Old Feb 23, 2011 | 06:12 PM
k5avj's Avatar
k5avj
Smile Update - 6 Months Laterink
I did take the '04 Dodge 2500 Diesel 2-wheel drive into Santa Fe & asked them to do a fluid flush. Well, that's not exactly what they did....as some of you may know. They linked into the lines going to the transmission cooler & did something like "dialysis" on my transmission.
The good news is that the truck is still going great now with about 225K miles. The noise I was hearing & thinking it might be the automatic transmission turned out to be u-joints. $150 later all is fine.
I did pull my 5th wheel back to Abilene from NM using my '98 2500 Diesel 5-speed manual (it has 325K miles).
Planning to pull next week to south Texas on an 800-mile round trip haul.
Thanks to all...
Lynn
'04 Dodge Ram diesel 2500 automatic
'98 Dodge Ram diesel 2500 manual
Old Feb 24, 2011 | 08:32 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
THX for the feedback
