keeps shutting off??
Old Aug 8, 2010 | 05:50 PM
red ram ridin's Avatar
red ram ridin
how would i check the battery otherwise?
Old Aug 8, 2010 | 09:10 PM
luckydt's Avatar
luckydt
drive to your nearest autozone. They have a battery tester and will do it for free. You didn't mention it, but is the check engine light on?
Old Aug 8, 2010 | 10:35 PM
red ram ridin
check engine light is not on. and when i started it after refueling it started right up, so maybe i didnt run out of gas, maybe it just died like its been doing and i just thought it did since it was so low on gas. it still dies when coming to a stop and doesnt idle correctly.
Old Aug 9, 2010 | 06:21 PM
red ram ridin
battery is perfect...
Old Aug 9, 2010 | 06:22 PM
red ram ridin
also reset PCM
Old Aug 9, 2010 | 08:54 PM
luckydt's Avatar
luckydt
have you checked your throttle body? Check to see if its got black covered on the butterfly. The only thing i can think of other than that is maybe a loose wire on the fuel pump when you hit the brakes coming up to the light it grounds out.
Old Aug 9, 2010 | 08:58 PM
red ram ridin
You think the fuel injectors might be clogged?
Old Aug 9, 2010 | 09:24 PM
luckydt's Avatar
luckydt
Unfort without having a SuperChip or Diablosport tuner to do some real time monitoring, without taking it to the dealership you mabye shooting in the dark to fix this.
Old Aug 9, 2010 | 09:31 PM
red ram ridin
I think i might try getting some fuel injector cleaner from walmart and running that through and if that doesnt fix it ill take it to a shop and they can check it out and look at my IAC and throttle body
Old Aug 9, 2010 | 10:28 PM
red ram ridin
It appears as tho my cab lights also flicker when i rev the motor...
