Got me buffaloed... vibration?
Old Aug 8, 2010 | 11:10 AM
Tazman40's Avatar
Tazman40
Default Got me buffaloed... vibration?
My 06 has got me stumped.Its hard to explain but between 40 mph and 45 i can feel this ever so mild vibration in the throttle pedel and steering wheel.A few weeks ago it started as a very mild ticking feeling and then went away for a few days.I thought it was a rock in one of my Zeons.Now its the very sutle vibration.It does it in gear and coasting in neutral.I have jacked it up,front and back at least a half dozen times and shook,pried,kicked, the tires,u name it ive done it.I cant find any loose parts.I thought it might be a front wheel bearing but still not sure.I had the tires rotated and balanced a few weeks ago.It almost feels like a big lugged mud tire vibration.I almost chalked it up to that but i dont think the zeon lugs are big enough to do it.Ive checked air preasure with no help.Have also checked all the u joints.
One thing i did find is when i jack the rear up i get a very little up and down movement with a bar prying under the tire on both sides.Im not sure how much axle play there is on these so i dont know if the bearings are getting bad or not.
Any ideas would be appreciated,shes got me beating my head against the wall.Little things like this drive me nuts.
Old Aug 8, 2010 | 01:36 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Maybe it is just a slight balancing issue with the tires
Old Aug 8, 2010 | 02:23 PM
Marx's Avatar
Marx
ya you could have lost a wheel weight, and chunks of rubber missing?
Old Aug 8, 2010 | 03:15 PM
Tazman40's Avatar
Tazman40
Well i thought the same.Tires look good yet and i did check for missing weight.What i did just do is put 54 lbs in them,4 lbs over recommended just to see.Drove it around and it is better,still barely feel it,but not like it was, so im chaulking it up to tires.Just have to see if it gets worse.
thanks for the replys
Old Aug 8, 2010 | 04:18 PM
Matt99's Avatar
Matt99
Go to where you bought the tires and get them balanced, should do it for free
Old Aug 8, 2010 | 04:28 PM
bamataco's Avatar
bamataco
There is a slight posibility that one of the tires is out of round. Maybe by only a little bit. I had a company truck and couldn't find the problem. I eventually guessed at this. And it turned out to be the problem.
Old Aug 8, 2010 | 04:31 PM
Tazman40's Avatar
Tazman40
I had them balanced and rotated like 3 weeks ago when i had it inspected but that doesnt mean one couldnt be a little out of wack again.I think by winter im gonna get different tires being these really suck in the snow.My goal is to get 17 inch wheels and tires and get rid of these big donuts but im not sure the budget is gonna allow it this year.
Old Aug 8, 2010 | 04:40 PM
outcast's Avatar
outcast
my boss's truck did the same thing and it turned out to be a cracked front hub he replaced it and the other one broke like 5k miles later
Old Aug 8, 2010 | 07:52 PM
Tazman40's Avatar
Tazman40
hmmmm,well thats interesting,ill have to do a closer inspection of the front end.Thanks for the info
Old Aug 8, 2010 | 09:05 PM
luckydt's Avatar
luckydt
Do a search on google. These trucks are known for a vibration in the speeds you speak of. It has been known to be the driveshaft out of balance and or the bearing that meets the driveshaft being shot. It also states that sometimes those fix the issue and sometimes they don't. The dodge dealerships know about this problem and there really isn't a fix other then guessing. Hopefully you get lucky and it's just the tire out of round.
