ABS issue
Old Aug 8, 2010 | 08:41 PM
Superchargedram's Avatar
Superchargedram
Default ABS issue
I have a blinking abs light that will not go off and I guess is whats causing the truck not to have any gears at all, Its not throwing any codes that I can read on the scanner. ALL the indicator lights are light up on the column as well PRND12 any help would be apperciated
Old Aug 8, 2010 | 11:14 PM
RedTruck-VA's Avatar
RedTruck-VA
I don't think the ABS warning is the root of your prpblem. This seems more like a lost of power or signal to the TCM or a damaged TCM. Have you done any electrical work recently? What does the truck do or doesn't do?
Old Aug 9, 2010 | 09:47 AM
brettj2408's Avatar
brettj2408
you will need a chrysler scan tool to read specific codes and go into the ABS module.
as in your PRNDL is lit up do you mean boxes around all of your gears? instead of a box around just the 1 gear you are in?
