Vibration above 60 mph
Old Aug 10, 2010 | 09:15 AM
Gasturbine's Avatar
Gasturbine
Worn u-joints can also cause vibration that feels like its coming from the wheels.
-Chris
Old Aug 10, 2010 | 09:16 AM
PhotogTom's Avatar
PhotogTom
It wasn't clear to me whether it started when the brakes were done or when the tires were replaced. Anyway, agree with brett WRT the brakes. Also, make sure that they put them back together properly.
I could tell a story or two about a certain "do-it-yourself" mechanic that may have reassembled something wrong once or twice. I won't mention any names, though....
Old Aug 10, 2010 | 04:58 PM
blakeroberts88's Avatar
blakeroberts88
Thanks for the input guys. The vibration is a whole separate issue from the rubbing. I'm sure just one of the wheels needs to be re-balanced and I'll check the tie rods, wheel bearings, etc. As far as the rubbing goes it might be a rotor that needs to be shaved. I've heard stories or rotors being warped right out of the box.
Old Aug 11, 2010 | 02:20 PM
rocket23's Avatar
rocket23
Another satisfied customer. Incidently, to check a u-joint vibration. roll down the road at a good clip, and shift to neutral.if there is a vibration then, it is a u-joint problem.
