loss of throttle response
Old Aug 9, 2010 | 07:30 PM
chris015's Avatar
chris015
Default loss of throttle response
03 1500 5.7
complete tuneup 40k miles ago with champ platinums.(02 sensors,cat went bad,replaced that..then fuel filter,plugs,wires etc the whole works
it has a k&n drop in filter,i clean it every 20k miles or so. Im getting 16mpg city.
did all that at 100k miles^^^
ran great!
51k later
the throttle response has sucked now for a while,i have cleaned the throttle body,seafoamed the truck, ran all those "amazing" additives etc. and still no help.
i can be going 55 mpg and slam the gas and it takes 1/3 of a sec for it to realize "oh i need to go"..or i can just tap on the throttle and it does nothing.any ideas?
other problems
it idles at 800 then 500 off and on during the day at redlights etc. and the powersteering rack etc is leaking. which i heard was common which i just top off with fluid every once in a while
Old Aug 9, 2010 | 07:48 PM
brettj2408's Avatar
brettj2408
hemis like copper core plugs rather than the more expensive platnium plugs. pull a plug and inspect it.
it your etc light on your dash?
try a throttle re-learn.
turn the truck to run with the engine off slowly push down the pedal in stages. (take like 5 to 8 seconds to push it all the way down then slowly lift your foot off the pedal taking time about 5 - 8 seconds as well.
then turn truck off and start it and see if that helped
Old Aug 10, 2010 | 08:07 PM
FrostKing's Avatar
FrostKing
Originally Posted by chris015
03 1500 5.7
ran great!
51k later
other problems
Yes, get rid of the platinum plugs and check your coils for signs of overheating / melting. I just replaced my '03 throttlebody and it runs at least a thousand times better. I should have done it 3 years ago. The blade design has also changed as well as there being a TSB regarding our throttle-bodies and a reflash for the computer.
