Build Sheet Question
Old Aug 12, 2010 | 11:21 AM
BlakeCP29's Avatar
BlakeCP29
Default Build Sheet Question
I have the lonestar edition and it says under optional equipment that the lonestar edition has 3.92 axle ratio, but further under optional equipment it says i have multi-speed overdrive automatic transmission with tip start and 3.55 axle ratio. so which is it? hopefully the first!
Old Aug 12, 2010 | 01:05 PM
dirtydog's Avatar
dirtydog
Moderate User
Standard eqiup is 3:55 and Optional equip overrides standard, but there should only be 3:92 as mine does under Standard as I have the Bighorn package.
Multi-speed blah blah blah is all about nothing. You have a 5spd auto trans same as they put in all Rams 2003+
You can check on your rear end tag what gears you have if you have additional concern.
