Help with a transfer case leak
Old Aug 14, 2010 | 03:20 PM
huseman808's Avatar
huseman808
Default Help with a transfer case leak
I noticed today that my transfer case has a pretty decent drip. After sitting for about 2 hours there was a baseball size drip on the ground. To me it looks like its leaking from where the case is split, but im not 100%. It looks like it might have been apart before , i think i see formagasket on it.
Is there any simple fix for this, like a Barsleak or something. i really dont wanna have to drop the case if i dont have to.
Thanks.
Old Aug 14, 2010 | 04:39 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would clean the transfer case and then see where its leaking from.No bar leak will not fix the leak. You should have gray silicone for your gasket. The best way to fix the leak and i know you don't want to hear this.Remove the t-case and repair the leak.
