Nitto Trail Grappler Pressure
So I just got the Nitto Trail Grapps (295-70-18) and I checked the tire pressure today and they were all around 50psi cold. Is this about normal for these tires? What is everybody else running for pressure in these things? I ran about 40 in my stockers, but 50 seems like it might be a bit high for a tire that has a 3-ply side wall and is E rated, but I may be wrong?
Also how often should I rotate/balance still every 6000mi?
on
That's an 80 psi max tire isn't it? I'd not run it much below 50 psi for daily, on-pavement use or you'll get premature wear. As a rule of thumb, I run a tire between 70-80% of the max cold tire pressure rating on the side of the tire for best handling and wear on pavement. I may air down when I go off-road, but I'll bring 'em back up as soon as I'm done...
I'm currently running 40 psi in my stock 275 x 60 x R20 chrome clads.
I do put in 45psi for quick highway and when carrying 4 adults.
Al.
most of the sensors arent calibrated to a psi unless they can show your psi in real time, usualy they are set for common psi and when one or more sensors detect a difference they will throw the tire light on. so if you had 10psi in all of your tires at the same time you wont throw a light after you reset it.
