4.56 gears
Old Aug 15, 2010 | 10:19 AM
BigRed1023's Avatar
BigRed1023
Unhappy 4.56 gears
I have a 05 Dodge Q.C. I need to replace my rear end gears. I have 4.56 gears in it but I dont know if all is bad or not i believe it is just the pinion bearings but if that is bad is all of it bad? I also need suggestions on where to buy the whole set up sider gears and all. I want the best not any cheap stuff please if anyone out there knows anything let me know. Thanks.
Old Aug 15, 2010 | 03:12 PM
jasonw's Avatar
jasonw
Site Moderator
Let me move this over to the 3rd gen section for ya, get you some help.
Welcome to DF!
Old Aug 15, 2010 | 03:29 PM
OlDirtyJohn's Avatar
OlDirtyJohn
4.56 gears are arguably the best ratio you can get in the rear. question though, why do you need to replace them? did your rear end blow up due to the stock LSD?
the best deal you will probably find for gears and install kit is at www.moesperformance.com. he has all the stuff you need bundled together into a package deal.
Old Aug 16, 2010 | 12:40 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
My question is what was done to damage the gears that you need to replace them? That cannot be good.
Old Aug 16, 2010 | 12:46 AM
gasguy's Avatar
gasguy
Dirty,
how can the stock lsd be attributed to blowing up the rear end...seroius question, not LOLing. Would this be something i should be concerned about in my 2500?
Old Aug 16, 2010 | 02:16 AM
abarmby's Avatar
abarmby
Originally Posted by gasguy
Dirty,
It's not a problem for you my friend, with a 2500. The 1500's had serious problems in the early days, with the LSD clutch pack retaining clips.
These would get damaged, work their way out of their locating pockets and either chew up the gears or cut into the carrier.
The 2500's don't have this problem so your good.
Al.
