shifting clunk
Old Aug 15, 2010 | 06:19 PM
srw1990's Avatar
srw1990
Default shifting clunk
Whats going on guys i drive a 04 ram hemi 60k miles.L atley when i take off and shift into drive i hear a clank. I figured it was the universal joints so i went ahead and bought them, then today i finally got around to doing the job. I got the driveshaft out and changed the rear one and it was fine everything was greased all the needle bearings in place so i put it back together and realized that wasnt the issue, i moved around the rear around and can feel a little play with the truck jacked up moving the tire. Do you guys have any ideas what the next step i should take is? thanks alot for your insight. Steve
Old Aug 15, 2010 | 06:26 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
If its in the rear diff, it could be backlash. You could remove the axles and adjust the side bearings,and see if the clank is gone.
Old Aug 15, 2010 | 11:06 PM
tsnyder's Avatar
tsnyder
i get the same thing it comes and goes i recently had put my truck to stock with my sc 6815 and the flashed it for a egr update and when i got it back was fine but once i put my chip back in and to performance it had a huge delay then slam it would go into gear .
they did replace my rightside axle seal due to it was leaking could this what u posted above be my issue??
