Question: 4"in. Exhaust?
Old Aug 17, 2010 | 08:30 AM
megablacktank's Avatar
megablacktank
Default Question: 4"in. Exhaust?
Okay so my little bro has this 5in. tip we were talking about slapping on the mega here latley. But know he has his old 4" exhaust from his cummins. How bad of a power lose could I expect by running his 4" exhaust on my truck? I was looking for a different tone and with adding that 5" tip would surely give it a different tone no doubt! So lets here it. Oh I will also get a 3" tp 4" adapter piece to put it all together with some slight modding I would imagine.
Old Aug 17, 2010 | 08:42 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You already know what Im going to day. We already talked about it. BTW......go do some work
Old Aug 17, 2010 | 08:55 AM
brettj2408's Avatar
brettj2408
so le tme get this straight...
you want to put a 4" single tube exhaust from a CUMMINS on your megacab HEMI?
one question..... WHY?
Old Aug 17, 2010 | 09:25 AM
megablacktank
Cause I can!!! aside from that and a new exhaust tone no real reason!
And yes weed I know we talked about it already and I am working, working hard at finding an answer!!
Old Aug 17, 2010 | 09:32 AM
brettj2408's Avatar
brettj2408
ok for one. you have a megacab
who knows what his truck is. your mega cab will be way too long so it will be short.
it also is probably rusted or cut into pieces from trying to get it out from under the truck,
its got a cat from a diesel with sut build-up from it,
the downpipe came from the turbo not an exhaust manifold.
different style hangers down the whole system.
just some reasons i could think of
Old Aug 17, 2010 | 06:14 PM
horatio102's Avatar
horatio102
mega cab is roughly the same length as a qc longbox, give or take an inch. If that's what he's got, it will be fine length-wise.
It's too much pipe though, you're going to lose torque down low. If it's off a 6.7 liter cummins, it's got a lot of crap you don't want in it, you'd be much better off buying a stick or two of 4" and have it custom bent if you want to lose torque.
Old Aug 17, 2010 | 10:20 PM
TRXHemi's Avatar
TRXHemi
You will probably lose some low end torque with that big of an exhaust, don't you think?
Old Aug 17, 2010 | 10:42 PM
HammerZ71's Avatar
HammerZ71
Dynos show significant drops in performance after 3" on gasser V8s. Most of the scavenging effect is lost.
Old Aug 19, 2010 | 08:21 AM
megablacktank
Yes it is off a 5.9 cummins. No it is not hacked up and t has a deletion pipe on it already. His truck is an 06' I think, so the rust is minimal if any. If it was to be run, we were going to cut it short for it would not make the length of my truck. We were gonna dump it right there in front of the rear tire with the 5" tip. Maybe I will stick with just some 3" and a 5" tip instead of running the 4" cause I need all the bottome end I can get to get her big *** moving.
Old Aug 19, 2010 | 08:43 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I will trade trucks with you...........
