Does Octane Matter?
Old Aug 20, 2010 | 08:56 AM
  #31
RubberFrog's Avatar
RubberFrog
You're wasting your time weed. Unless they're running a gauge to monitor kr, they'll just never get it.
Old Aug 20, 2010 | 09:04 AM
  #32
weedahoe's Avatar
weedahoe
Hall of Fame Member
I know it is one of those things where you just gotta see it to believe it. Unfortunately, we (humans) cannot see, detect and hear what those sensors are designed to hear.
Old Aug 20, 2010 | 09:41 AM
  #33
Grenadedodger's Avatar
Grenadedodger
I'll defer to your expertise. We're an engine rebuild shop, not tuners, and we typically work on BMW and Toyota vs. Dodge.
Originally Posted by weedahoe
I have got to politely call BS on this one. YOU may not know, see or hear the difference but your ENGINE does.
Again, if you have a tuner and can look at your PID logs and read the differences in those PID and tuning logs from 87 to 93 you will see a world of difference.
Just because you can run a tank or 87 (or even several) and not have any adverse side affects does not mean your knock sensors dont notice the lesser grade fuel.
Again as and said in port #22, sure it will work but if you truly understand the internals and designs of an engine and blends of fuel, you will know what you can and should use.
And yes, you are right that Dodge Ram PCMs do not auto adjust base spark or other tuning features. Those have to be written to the PCM via custom tuning.
Old Aug 20, 2010 | 12:41 PM
  #34
canadianbrute's Avatar
canadianbrute
Wow. I learned a lot in this thread.
Old Aug 21, 2010 | 03:51 PM
  #35
meen green machine's Avatar
meen green machine
this gives me kind of a sour feeling. in a few months im supposed t get my dads truck which is an 07 hemi. and it has 60000 miles and he has run the lowest gade fuel since the day hes gotten it which im pretty sure is 87. You guys think the engine will have quite a bit of suffering from this?
Old Aug 21, 2010 | 04:04 PM
  #36
HammerZ71's Avatar
HammerZ71
I know guys who've run nuthin' but 87 octane on a Hemi and have well over 100k miles on it with no apparent problems, but I will say that most times when someone has a major cylinder issue on this engine, the owner has admitted to using primarily 87 octane fuel.
Old Aug 21, 2010 | 04:15 PM
  #37
weedahoe's Avatar
weedahoe
Hall of Fame Member
Thats true what Hammer says. Its not the question can you use lower octanes and will it work, the OP asked did octane matter and that all depends on what you mean by "matter".
Old Aug 21, 2010 | 04:55 PM
  #38
meen green machine
ok good. well as soon as i get it it ill make sure to make the switch
Old Aug 21, 2010 | 08:29 PM
  #39
ram_bo06's Avatar
ram_bo06
interesting...
Old Sep 7, 2010 | 10:57 AM
  #40
weedahoe's Avatar
weedahoe
Hall of Fame Member
Here is a thread with some pics of someone use 87 too much and too often.....and now he knows it too
http://tinyurl.com/26fd7r8
