Sagging leaf springs
Old Aug 21, 2010 | 01:26 PM
RDJ77's Avatar
RDJ77
Default Sagging leaf springs
I have a 2006 1500 QC 4x4 and after a 5000 mile trip loaded down, it looks like my rear end is sagging. I am just wondering what my options are to bring the rear back up. I am also thinking about putting a 2" lift on (just for bigger tires), but that just means I will be sagging two inches taller. Should I just replace the leafs or do you know of a better way to bring it back up? Thanks
RJ
Old Aug 21, 2010 | 01:37 PM
Paratrooper's Avatar
Paratrooper
first id post pics just so i could see if it really is sagging or not second if they are just replace the rear leafs with 2 inch taller ones maybe even heavier duty ones too if you have the money or 3 you could install some hellwig helper leafs its all up to your budget
Old Aug 21, 2010 | 01:45 PM
Marx's Avatar
Marx
lift shackles are good
how much weight would you say you had?
Old Aug 21, 2010 | 03:50 PM
RDJ77's Avatar
RDJ77
We were pulling a trailer and had the back loaded. Total was 4000lbs extra. The trailer had a wheeler and a motorcyle on it. The problem was we drove through upper Canada (no offense) and the roads suck. Lots of humps and bounces. I think that is what caused it. I looked at the springs and you can see they are bowed over the axel. Here are some pics.
Old Aug 21, 2010 | 06:12 PM
PhotogTom's Avatar
PhotogTom
There's been some discussion as to whether the springs are normally slightly bowed over the axle like that or not. Mine are. My friend's are. Several folks have them like that. But maybe not everybody.
How does it sit? How are the headlights aimed? If they higher than they used to be, then the back is sagging.
How much of that load was on the truck (tongue weight + stuff in the bed)?
Old Aug 22, 2010 | 10:23 AM
Paratrooper
my truck is damn near new and iv never had a load in the back besides typical Home depo stuff and mine have a slight "bow" if you can call it that so im sure ur normal
Old Aug 22, 2010 | 10:28 AM
PhotogTom's Avatar
PhotogTom
I had a thread on this a few weeks ago.
Here's mine:
Note: I have since replaced the sorry-looking worn out tires.
Old Aug 22, 2010 | 03:44 PM
Big_Wheel's Avatar
Big_Wheel
mines doing the same thing---drivers side more so. im gonna hve to get new springs next year i think once i get back from afghanistan. can't dis mine too bad though its a 2004 with 140 000kms on it
Old Aug 22, 2010 | 05:46 PM
RDJ77's Avatar
RDJ77
Here are before and after pics. I couldnt figure out how to add the pics in the post, so I had to delete the spring pics to add these.
Attached Thumbnails Sagging leaf springs-005-2.jpg   Sagging leaf springs-dsc_1091-2.jpg
Old Aug 22, 2010 | 06:28 PM
Gone Fishin's Avatar
Gone Fishin
To the OP, you could go to a brake and spring shop and have the leafs re-arched, I'm sure for a fraction of the cost of new---unless - of course - you end up doing a lift
