strange starting problem
Old Aug 22, 2010 | 02:09 PM
tdeerman's Avatar
tdeerman
Question strange starting problem
2002 4.7 1500 No codes indicated when scanned or on self test. If it sits for about 20 min. it is has to turn over several times before starting. Starts quicker with trottle fully open. Once started, it will crank at the touch of the key as may times as you try. If it sits for 5 days it will crank at the touch of the key the first time. Fuel pressure jumps to 48 psi as soon as switch is turned on(new fuel pump). However, the pressure bleeds off in about 5 min. when turned off. Is that normal? Replaced idle motor(no change). Smells rich with difficult start. Does not when starts easy. Could the injectors be leaking and flooding the cyl? It would have to be more than a couple to make it hard to start right???
Old Aug 22, 2010 | 03:54 PM
Big_Wheel's Avatar
Big_Wheel
maybe bad check valves...
Old Aug 23, 2010 | 12:41 PM
EvlKenevl's Avatar
EvlKenevl
I have the same problem and asked the questions.
I think its the injecters, but haven't had the time to check it out.
I ran some injecter cleaner through(OFF THE FUEL RAIL) but it didn't help.
good luck and if I figure it out I'll let you know
Old Aug 23, 2010 | 12:43 PM
EvlKenevl's Avatar
EvlKenevl
It wouldn't start for $h!t all time
Old Aug 23, 2010 | 03:54 PM
brettj2408's Avatar
brettj2408
pull your injectors and look at them. buy o-rings for when you put them back in.
Old Aug 23, 2010 | 04:55 PM
Gone Fishin's Avatar
Gone Fishin
Time for new injectors, or send those in and get them rebuilt
Old Aug 23, 2010 | 07:48 PM
Big_Wheel's Avatar
Big_Wheel
actually that depends how bad they are.....
