03 Ram Out of Nowhere Transmission Jerking/Pulling
I'll try and make this a quick summary.
03 1500 with approx 76K miles. 4.7 auto tran.
Out of the blue this past Thursday, driving to work, my transmission starts a kind of slingshotting feeling forward and backward with some light knocks here and there. Happened to and from work on that Thurs and on Fri.
I let it sit all weekend without driving, to take it to friends shop this morning (Mond 8/23). About a 10 mile drive. Didn't do it 1 time on the way.
He calls me at end of day after experiencing the jerking and says he thinks a filter change possibly, but he's not a tranny rebuild guy, and says it's prob gonna need a rebuild coming up.
Him and I noticed that it seems more prominant in the 3rd gear range. On the way home from picking it up, it starts out no prob, but like 5 min later starts again. Mostly highway miles home. Up around 60 miles an hour it's running smoother, but starts going into a higher sounding gear and back on it's own on and off, and a couple of really hard hits to the tranny.
So number 1, Why out of the blue does something like this start? And could it be the filter issues, or sensors somewhere making it flipout all the sudden. OR is that how a bad transmission starts..."out of the blue"?
COUPLE OTHER ADDED NOTES: TRAN FLUID IS RED/CLEAN. HAD FLUSH ABOUT 20K MILES AGO TOO.
I REPLACED THE "IOC" IN THE PAST BECAUSE OF IDLING ISSUES AND FIXED PROBLEM, BUT LATELY THE TRUCK STALLS AT A STOPLIGHT ONCE IN A WHILE (3 TIMES TODAY THOUGH), AND GETTING SPEEDOMETER BOBBING UP AND DOWN AGAIN.
FOR A WHILE NOW(OVER 6MTHS), MY INSTRUMENT PANEL IS SHOT, MOSTLY OFF WITH ALL WARNING LIGHTS ON, AND GAUGES DEAD, BUT COMES ON AND OFF HERE AND THERE. THIS EFFECTS, HEADLIGHTS/BREAKLIGHTS, AC COMPRESSOR, WIPERS, HORN, ETC.
Any tranny advice is appreciated and whatever bones you can throw me on the rest......THANKS!!!! Can't afford a rebuild really.
And lastly, are you getting any check engine lights or idiot lights on the dash lighting up when you have these issues or loose the instrument panel?
Thanks for the replies. I meant IAC, Idle Control Valve in my original post. An updated bit of info now is I tried turning OFF the Over Drive today at the shift handle, and it definitely seems to smooth out the jerking of the engine. Not 100% but it is doing something for the problem. I'm considering things like Transmission Solenoid, and someone above mentioned computer issues maybe?
So anyone have anything to say about the Overdrive comment above...anything I should look for there????
I have bought some cleaners to clean the air intake manifold, and the Idle control valve to see what that does with my idle and stalling. When I replaced the IAC before it got rid of those issues immediately. (throttle speed thing too).
Will clean the throttle body as well now, thanks weedahoe.
The instrument panel...I'm procrastinating taking that out to check all wiring and connections there...but it's about time I get to it.
76K miles, never had plugs replaced...I'm assuming would be a good idea too?
