Rear rotor removal?
Old Aug 26, 2010 | 01:47 PM
bigdaddyII's Avatar
bigdaddyII
Default Rear rotor removal?
Hey guys. Truck on jacks, changing rotors and pads to drilled/ ceremic. Fronts went like cake, back rotors won't come off. Am I missing something. E-brake is not on. Truck is 02 1500, 2wd.
Internet is out at the house so I'm on my Blackberry and can't search. Thanks for any help.
Old Aug 26, 2010 | 01:52 PM
bigdaddyII's Avatar
bigdaddyII
I have taken the stupid little retaining clips off as well. Boy, I haven't had this much friggin fun in a while fml.
Old Aug 26, 2010 | 03:15 PM
cwboyjohnny24's Avatar
cwboyjohnny24
There may be a star wheel on the inside of the brake in the back you will have to turn to make the parking brake pads release from the inside of the rotor.
Old Aug 26, 2010 | 03:48 PM
Bent's Avatar
Bent
I haven't done my own brakes, but the brake shop didn't find it too easy to remove my rear disks either.
Do the disks/rotors have holes for jack screws?
bigmac18's Avatar
bigmac18
It may just be corrosion causing the rotor to stick to the hub. Try some kind of lubricant (WD-40 or PB Blaster)
Old Aug 26, 2010 | 04:12 PM
bigdaddyII's Avatar
bigdaddyII
Thanks for the replies guys. Right after posting that I became pissed and decided not to fool with it. I farmed it out to a local mechanic. Cost me an extra $50 but I now know how to get them off. He got a BFH and beat the snot out of it, they came off, not easy but they came off.
Old Aug 26, 2010 | 04:56 PM
hemi_pwr's Avatar
hemi_pwr
The rear rotors are pretty tough sometimes, a bfh and some penetrating oil usualy do the trick. I will be doing mine this weekend.
Old Aug 26, 2010 | 05:06 PM
dragracer98's Avatar
dragracer98
yep that's exactly how i get mine off. Works like a charm.
Old Aug 26, 2010 | 05:24 PM
05SLTSPORT's Avatar
05SLTSPORT
yeah, just use a bfh if you want to replace your e-brake shoes. it only takes a couple minutes to turn down the star adjuster in the back. then a couple smacks
Old Aug 26, 2010 | 09:56 PM
bigdaddyII's Avatar
bigdaddyII
I hadnt seen a star adjuster.
