How to abs module
Old Aug 26, 2010 | 02:22 PM
dash80's Avatar
dash80
Default How to abs module
I'm going to change out my abs module/pump (rwal only) with a used one and was wondering if anyone had the proceedures on do this or any insight would help. It looks simple enough but the old Haynes manual doesn't say anything.
Old Aug 26, 2010 | 03:43 PM
bigmac18's Avatar
bigmac18
Is this what You're talking about?
Hope it helps.
Old Aug 27, 2010 | 02:16 PM
dash80's Avatar
dash80
You the man BigMac this is what I was looking for. Mine shorted out and burnt a hole through it. I'm curious if b/c it has a hole in it if I'm going to have to do anything special when bleeding the brakes or do I just bleed all four wheels? If you have the, brakes standard proceedure (sec 5) that might give me an idea?? Thanks for all the help!
Old Aug 27, 2010 | 02:25 PM
dash80's Avatar
dash80
One more thing... In the instructions on the 4 wheel abs unit it mentions that you have to get the CAB reprogrammed. I have the 2 wheel (rwal) and I was under the impression that it too had to be programmed. I will find out once it's on there I guess but curious if you know.
