Half Shaft
Old Aug 27, 2010 | 01:32 PM
Kristofeles's Avatar
Kristofeles
Talking Half Shaft
Does anybody ever replaced a half shaft? If Yes please give me some advise. I will replace mines soon. Is it easy to do? How much time?
Thanks
Old Aug 27, 2010 | 08:19 PM
Big_Wheel's Avatar
Big_Wheel
easy to do...just give it a good tug or use a pry bar to pop it off the diff out put shaft
Old Aug 28, 2010 | 12:31 PM
Kristofeles
When I put the shaft back in do I need to take any "special" steps?
Old Aug 28, 2010 | 12:45 PM
Big_Wheel's Avatar
Big_Wheel
not really just make sure the axle is seated over the snap ring on the output shaft and i've always used loctite on the axle nut
Old Aug 28, 2010 | 11:25 PM
Marklorenzo's Avatar
Marklorenzo
It took me about 6 hours to do mine. The shaft was basically melted onto the spline. Ended up having to grind it down the middle and torch the rest off. Used lots a force with a pry bar. I wish u the best of luck. How many miles are on the truck? I had a 160,000 and the boot busted so I had to bust down and change it. I hope yours comes out like the rest say they do, "Just Pull Out"
