2007 ram u1110,u0121 codes
Old Aug 29, 2010 | 01:07 AM
dave_thunderroad's Avatar
dave_thunderroad
Default 2007 ram u1110,u0121 codes
2007 ram 5.7..turned truck off for no longer than 5 minutes.when i restarted truck i have no speedo and abs light stays on....these 2 codes was what it gave...u1110 lost speedo signal...u0121 lost abs signal...any clues??truck still runs fine
Old Aug 29, 2010 | 03:23 AM
Marx's Avatar
Marx
check out this post
https://dodgeforum.com/forum/3rd-gen...es-lights.html
and here are the 2007 codes on the 3rd post
https://dodgeforum.com/forum/3rd-gen...m-alldata.html
Old Aug 29, 2010 | 06:31 PM
dave_thunderroad
well i thought it was fixed....replaced any missing fuses ,unhooked ground terminal from battery for at least an hour..went off for about 30 minutes then it came back on.looks like im dealer bound.
Old Aug 29, 2010 | 09:29 PM
luckydt's Avatar
luckydt
if you don't have any blown fuses or missing fuses including the "spares" because i had that problem with a blown "spare" fuse giving me exact problem you have. If it's not that then my guess is the $10 speed sensor on your rear diff it's a common issue.
Old Aug 30, 2010 | 02:48 AM
dave_thunderroad
well i looked again and found no blown spare fuse,but a fuse with corrosion on it in the spot that said vgt diesel...replaced with new one and lights went off and speedo works fine now...cleared codes by unhooking batt terminals..i have no clue what this fuse does in the 1500 but its sure not what the fuse panel says!!!!thanks for all the help
Old Aug 30, 2010 | 06:25 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
What fuse number was it you found to be an issue?
Old Aug 30, 2010 | 02:25 PM
dave_thunderroad
fuse # 37
Old Jun 6, 2012 | 09:00 AM
ajwesseler's Avatar
ajwesseler
Default #37 solved my problem
2007 ram 1500 laramie, replaced fuse 37, problem solved. It wasn't burned out either. Just a little wear.
