coil spring swap
ok so im about to get my kore leveling kit for my 2006 1500, im also getting 2.5 inch add-a-leafs for the *** end of the truck, what i want to try and do tho is get some different springs for the front end so that i can use spring for the lift rather than just raising the spring perch up on the front strut like the kore kit uses, so i was wondering if anyone knew the specs for our springs, diameter, length and spring rate, and if they had any ideas as to what springs i could possible put in there or am i going to have to get a custom spring made? im tryn to find something a bit stiffer than stock so i can stop bottoming out off-road
