What size fuse for Taurus Efan Mod??
Old Aug 29, 2010 | 01:15 PM
AaronOregon's Avatar
AaronOregon
Default What size fuse for Taurus Efan Mod??
I installed it yesterday on the low-speed fan wire (brown/orange) and through an adjustable flex-a-lite controller. I also have the power wire just stuck in one of the spare relay switched plugs on the fuse box. I put a 25 amp fuse in line. Is this good or to much or to little? Also, the guy at Napa is saying I need it through a relay now? If so, what size? I have searched and found no fuse size or relay talk other than guys going to the high-speed side and needing more. Thanks!
Aaron
Old Aug 29, 2010 | 02:38 PM
MikeHTally's Avatar
MikeHTally
It may pop that one a bit too often. I think they draw about 40 amps on startup. Someone else can jump in here and enlighten us.
Old Aug 29, 2010 | 04:03 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I had a 25 on my low side and never an issue and I put a 60 on the high side
Old Aug 29, 2010 | 05:49 PM
AF_HEMI's Avatar
AF_HEMI
the lowside has an inital startup surge of about 40 amps. The highside surge is about 80 amps. To be safe use a 30a on lowside, and 60a on highside
Old Aug 29, 2010 | 09:23 PM
luckydt's Avatar
luckydt
i have a 30a relay on mine with 30a fuse never had a problem running low side on a 3.0L fan
