i want to put a hitch on my truck !!! but i have a roll pan !!! HELP
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
and yeah redtruck....where did you get your traction bars, mine are the same but one is broken right now and my buddy said he couldnt get a new one. i need to fix that
yeah i saw a truck like mine with the hitch knotched right in the bottom of the pan and it looked ok to me. not too bad but it will work. and yeah mine has the crossmember i just looked it has the spare tire s*&t on it still but no tire, not worried about that. so should i just get a stock hitch ? u confused me a little bit
Sorry for the confusion, If you just bolt the OEM hitch up to the OEM cross member it may not fit just right. That was why I said some fabrication might be required to get the hitch set just the way you want it in relationship with the pan. Too bad I have all the bits and pieces you need but I'm flying out in the morning and will be gone for a while.
Actually, bolting up is not going to work at all. It will require custom fabrication. I was thinking vertical hieght only. The OEM hitch will also be sticking out too far to the rear. The simplest would be to have a shop fabricate the reciever in the location of your choosing. I have seen these 2x2 recievers available at trailer shops. Auto Zone, maybe even Wally World. The shop should be able to get it right for you. I'll be back in the spring. Modding season for me is officially over for the mean time. Good luck.
This is going to stick out too far..
OEM cross member
Good luck...
Hidden hitch
Yeah my truck has none of that actually I was wrong looking at something else, sorry I was working at the toime I looked. Where u going what u mean mod season is over ? U were a big help
