i want to put a hitch on my truck !!! but i have a roll pan !!! HELP
Old Aug 31, 2010 | 12:07 PM
runvs's Avatar
runvs
Default i want to put a hitch on my truck !!! but i have a roll pan !!! HELP
03 ram short bed i have a steel roll pan when i got the turck but the tag is off set to the right side corner of the pan, is there a hitch i can get or what can i do ?
Old Aug 31, 2010 | 12:33 PM
dakota_raven's Avatar
dakota_raven
There is a tag cover/flipping thingy that flips your tag down to use the hidden hitch. But you say you have the tag to the side of the pan, so i have no idea other than get a new pan with the tag in the middle!!!
Old Aug 31, 2010 | 12:43 PM
runvs's Avatar
runvs
yeha i saw a guy who had the same pan as mine with the hitch reciver below his pan and his truck was set up like mine but it was in a add so i couldnt ask him how they did it, nobody knows what i can do? do they make like a reese drop hitch kit or something
Old Aug 31, 2010 | 01:36 PM
Marx's Avatar
Marx
i dont how how often you tow but you could put a hitch on and when you tow just remove the roll pan
Old Aug 31, 2010 | 01:46 PM
runvs's Avatar
runvs
well my truck is completely shaved and molded together !!! :-( so i cant or i would do that, and i tow alot, is there a hitch drop kit or anything ?
Old Aug 31, 2010 | 02:50 PM
BadHab1t's Avatar
BadHab1t
you need a custom hitch made, loose the spare tire and have a square tube bolted or welded in between the frame rails then they take another piece of that 2" square tubing and have it welded to the spanner between the frame rails, but low enough to clear the roll pan but not so low it looks retarded or scrapes the ground....you follow what i mean...cause a hidden hitch is just this flipped upside down ....
Old Aug 31, 2010 | 04:07 PM
dakota_raven
You need something like this!!
But as i said before you need to get the license plate in the middle of the roll pan.....
http://sporttruckdirect.com/Street_Scene_Roll_Pans.html
got to this link and scroll down to dodge. Te pic is for a chevy but that's what you need!!
Hope it helps. Good Luck!!!
Old Aug 31, 2010 | 04:28 PM
RedTruck-VA's Avatar
RedTruck-VA
I hate to say it but you got a problem. Is the original cross member removed? If it is still there you might fab a reciever below the pan, but it would be too low on a lowered truck and IMO look odd. Your choces are not pretty, 1. buy a truck that suits your needs or re-install a hidden hitch and use the approipriate roll pan to hide the hitch. And depending what you are towing perhaps some helper bags if you need them
My pan uses a hitch setup like the one shown.
Good luck,
Old Aug 31, 2010 | 04:40 PM
dakota_raven
Good luck,
I just said that!!!!
Old Aug 31, 2010 | 05:00 PM
RedTruck-VA
Then that makes us both right!
