I think I bought the wrong reciever hitch!! UGH!
Old Aug 31, 2010 | 07:22 PM
2001Ram's Avatar
2001Ram
Default I think I bought the wrong reciever hitch!! UGH!
After all ive done and the nice guys on here helping. I think I have the wrong hitch.
These holes:
Do not match up on the tubular bar that goes across under the bumper. they are about an inch apart........
If I got the wrong one, then what does this stupid thing fit?
Old Aug 31, 2010 | 07:32 PM
horatio102's Avatar
horatio102
I dunno, but that looks similar to mine, except mine's got a 12000 pound max leveling weight, not 10000.
Edit: You've got a 1/2 ton? Bolt the two that do line up, then go get the rest of it welded up. IIRC the factory welds them on anyway.
Old Aug 31, 2010 | 08:59 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If the holes are off and thats all, can you drill new holes?
Old Aug 31, 2010 | 09:27 PM
rtmtrrdr's Avatar
rtmtrrdr
according to everything I've looked at (IE:dodge.com,moparonlineparts.com,dodge parts.com,popar.com) 02-08 should all be the same.it's the exact same one I put on my 05.the numbers match and everything.Tomorrow I'll take a pic of it on for you and you can see if it's set up the same way yours is.
Old Aug 31, 2010 | 10:44 PM
2001Ram's Avatar
2001Ram
Its welded on? WTF? There are two holes on the back right? There is also a small gap in between the tube bar and reciever hitch..
Old Aug 31, 2010 | 11:15 PM
That1guy's Avatar
That1guy
Exchange it for the right one?
Old Sep 1, 2010 | 12:36 AM
2001Ram's Avatar
2001Ram
I bought it on craigslist for $40
Old Sep 1, 2010 | 01:24 PM
horatio102's Avatar
horatio102
Ok I just checked mine, and no it's not welded on. Someone said they were and I took their word for it.
Mine's bolted on, the number on the top is 58903, it's 12,000/1200 and 5000/500.
Old Sep 1, 2010 | 06:41 PM
rtmtrrdr's Avatar
rtmtrrdr
There not welded on.This how it is on my 05...
This is from the top side of the bumper.Under the dodge cap it 3 bolt holes,Usually the middle one is not plugged because everyone just puts a ball there.The other 2 on the sides are covered up by the bumper step pad.You can take the pad completely off and then put it back on after you have installed the hitch,But it's a PITA.I just cut the holes out of the pad and found this cap on e-bay for $20.
http://s706.photobucket.com/albums/w...t=IMG_0353.jpg
This is from the side.You can see one of the side bolts and how it goes around the tube to the back bolts
http://s706.photobucket.com/albums/w...t=IMG_0355.jpg
And this is just for the back bolts.
http://s706.photobucket.com/albums/w...t=IMG_0354.jpg
I don't know if this will help much.But i'm trying.Let me know if you want anymore pics and I'll try to get them for you
