power window
Old May 27, 2005 | 09:47 PM
pythonbunny's Avatar
pythonbunny
Default power window
i have a 2003 1500 qc power all. now the window switch will not work on the passenger side, but if i use the one on the driver side it works fine. is this a bad switch or something else. it just did it today and never had a problem, also is this thing expensive and what would a dealer charge to install.
Old May 27, 2005 | 10:03 PM
ramfan5.9's Avatar
ramfan5.9
Default RE: power window
its prolly just the selinoid in the switch
Old May 27, 2005 | 10:50 PM
sig's Avatar
sig
did you check the passenger window locks on your controls?
Old May 27, 2005 | 11:42 PM
pythonbunny
yes i did check the lock and it didnt matter if it was locked or not!
Old May 28, 2005 | 02:39 PM
pythonbunny
thanks for your input everyone i found that the wire came off the driverside control so the back and the passenger side didnt work along with my power mirror reconnected the wire harness and it all works..thank you
