quick question for ur lifted ram guys
Old Sep 2, 2010 | 12:54 AM
mattstang's Avatar
mattstang
Default quick question for ur lifted ram guys
i got a 04 rumble bee 4x4 i read that i could get 35's on with just a leveling kit would that work for me beings that i get the bee with the extra ground effects or should they come off i got the truck on the cheap and really it more of a third whip only planing on really offroading and useing for camping/hunting i no i will probley rub wheeling hard as i usually do so i planed on maybee a body lift if so would it clear 36's with no major rubbing sorry for the questions but just courious i thinking maybe the bigger the better any suggestions
Old Sep 2, 2010 | 12:58 AM
Ice-Forever's Avatar
Ice-Forever
I would lose all the ground effects. Yeah you can fit 35s with just a level, but it will rub in certain situations (Full lock on an incline for example). Also I would recommend getting new shocks as well. As for the bigger tires I am not sure. Honestly, I am looking to stick with my 35s and sometime down the road I would like to get a 3" body lift and I would be happy around there
Old Sep 2, 2010 | 12:59 AM
HammerZ71's Avatar
HammerZ71
35s fit with just a level but don't leave much room for articulation. IMO if you are going to actually use the truck off-road or to haul, go at least body lift/level combo if you want 35s. Much bigger than 35" tires and you start to run the risk of running your front CV shafts at too much of an angle, significantly weakening them. If you want bigger than 35s you really need to be looking for a SFA truck "on the cheap"...
Old Sep 2, 2010 | 01:08 AM
mattstang's Avatar
mattstang
yeh i was going to but bought this truck for 5gs so really couldnt complain if i did i would have upgraded the stock rear anyway because they were only 44's correct i acually thought about converting to a dana 60 solid in the front in the next year or so do they sell upgraded yukon axel cvd's or is it still just to week to get me by
Old Sep 2, 2010 | 01:28 AM
HammerZ71's Avatar
HammerZ71
Rear is a AAM 9.25", front is an 8" IFS. Chrysler went away from Dana with the 2nd Gen Rams. Not really that weak of a CV setup UNTIL you increase the angle of the joints, they get progressively weaker as the angle increases.
Some guys run 37s with no problem, but I've had a few in my hunting club snap 'em running 37s. You also have a lot of weight when the tires start getting that big.
Strongest setup for 37s would be a 4" suspension lift and 3" body combo as the 4" lift is easier on the CV angle than a 6" would be and of course a body lift does not effect suspension.
Old Sep 2, 2010 | 01:59 AM
mattstang's Avatar
mattstang
yep i am totaly fimilar with 2 gen rams and i no mine is ifs and by experance with lifting up quads with bigger tires and how week the cvd's get when the angel is bad it sucks i am shure it would be the same with the trucks so i think ill stick with 35;s or 36 at the most. i would love the 4 sus lift and 3 body but this hell hole state i live in i can only be a total of 9 inches of lift wheels+ tires so that kindof limits what i can do
