ticking noise? hemi
Old Sep 6, 2010 | 07:20 PM
fordmandodgefan's Avatar
fordmandodgefan
Default ticking noise? hemi
04 hem 1500 110'000 miles i loud thicking when first start then quites but always ticks i use 10w 30 oil i belive it is the lifters (know issue) but might be the exahust leaking a lil. if it is the lifter where do you get new ones cheap
Old Sep 6, 2010 | 10:14 PM
PRF66's Avatar
PRF66
I don't know where you get the lifters cheap, but I just had a lot of in warranty work done on my 07 Ram and the parts were not cheap. The work was performed in order to correct my complaints on the "hemi tick" which for now is no longer. What I'd like to know is what oil the dealer put in the truck 5w 20 generic? There is only a long code number for 7 quarts on the receipt and it crosses to 5w20, but is it synthetic. I had been running Mobil 1 and I am strongly considering using BND products Aces IV and Quantum Blue. They were nice enough to talk to me prior to my complaints to Chrysler and I think the product may be a great answer. Perhaps you could call them? They might suggest use of their product before you pop for new parts. If it were not for the warranty from Chrysler and the repairs being covered, I know I would have bought the Aces IV and Quantum Blue first. Then,if it didn't help,I'd repair the engine. Good luck. Regards, Michael
Old Sep 7, 2010 | 07:53 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
04 hydraulic tappets (lifters) are P/N 53021720AB and are about $60. Some guys find that their exhaust manifold bolts have broken and cause a "tick". Other find that by swapping out their 5.7 push rods for 6.1 push rods (about $11) they loose their "tick". Other finds that synthetic oils lessen the noise and some like replacing all the internals and replacing valve guides as well.
If you want those lifters, then go over to http://www.wermopar.com/ or call the dealer.
Old Sep 8, 2010 | 08:36 PM
fordmandodgefan
thinks ill look in those and is that a dodge part number
