Changing Exhaust Manifold bolts/studs
Old Sep 8, 2010 | 07:55 AM
Ramer05's Avatar
Ramer05
Default Changing Exhaust Manifold bolts/studs
Dose anyone know the torque specs on the the exhaust manifold bolts/studs?
I had 2 of the studs break off in the head SOMEHOW? trying to replace all of them and stop a nasty exhaust leak!
Old Sep 8, 2010 | 08:17 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I can only assume you have a 5.7
INSTALLATION
EXHAUST MANIFOLD
(1) Install manifold gasket and manifold.
(2) Install manifold bolts and tighten to 25 N·m (18 ft. lbs.).
(3) Install heat shield and tighten nuts to 15 N·m (11 ft. lbs.).
(4) Lower engine.
Get your Srvc Man here
https://dodgeforum.com/forum/3rd-gen...-download.html
