P0032 recurring
So i got the code about 2 weeks ago, today i put a new o2 sensor in and did my plugs, pretty much a tune up. Cleared out the codes and the P0032 code came right back, ever since it originally went the truck idles rough when sitting at a light in gear and when its cold feels like its hesitating. I also did a compression test today and those were fine. But im at a loss for why the code is still up, any suggestions?
After i change out a bad sensor i always clear the code then pull the + battery cable off and ground it to reset the pcm.
If that doesnt work i would take the new sensor back and swap it for a new one if its under warranty.
Trending Topics
Hey Guys, I am having the same trouble with my O2 Sensor. I have changed the B1S1, B2S1, and B1S2 just to try them all. Still get the code. Zero, is this what happened to you and it was your PCM? I have tried grounding the pcm to clear, no dice. Two different code readers, no dice. I also have a Power Tuner that I can watch the voltage on the O2 sensors, B1S1 does seem a little high (1.0 when others read .8). I dont even want to know what a PCM costs......(maybe I do, lol). I have been up and down a lot of forums, this one seems the most helpul. Thx Gents!
2008 Ram 1500 5.7 Hemi
