3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Yeah 456 gears all the way man.....they do great around town and Actually good on highway, but if u want top end speed stay stock, they don't pull as hard at high rpm but low or towing they r great....ill never change em outta my truck....
I'm located in greenville sc off woodruff road man pm me sometime
Unless you are driving at 120mph+ the top end will not be affected at all. Even if you like taking the truck down to the track for some fun you'll still be fine unless you do some major mods which cause you to shift out of 3rd early. Think of it this way, the SRT-10's come stock with a 4.56 gear, if they thought it affect the trucks performance at all do you think they would put them in their "performance" truck?
Just an FYI the drive shaft in mine is not aluminum, its rusty as hell and its a 4x2, probably a quad cab thing.
It is.
SRT-10 quad cabs come with a 4.56. The Reg cabs come with 4.10's.
4.56s are the way to go, with 33s I run 2400 rpm @ 75mph, still get 18 mpg. Picked up about 1 mpg in town with the new gears, and much better acceleration over 3.92s. Plus, the tall gears keep you in the power band, so there is no lag when you're crusing at 45-60 and need to put your foot down to pass. Hands down the best mod ever (with the possible exception of the Auburn LSD)
Pyro what all do you have done to your truck? I am pretty much the same truck as you 4.56's and 33's but I get 12 mpg's.
