Broken Spark Plug?
Old Sep 13, 2010 | 11:15 AM
jerick's Avatar
jerick
Default Broken Spark Plug?
I have an 02 Ram 1500. When I was changing the spark plugs one of them broken just above the threads. I was wonder if there is anyway to remove the plug without pulling the head? Your help is appreciated. Thanks.
Old Sep 13, 2010 | 11:48 AM
dragracer98's Avatar
dragracer98
I have never broken a spark plug so i don't know what it looks like inside but if there is a good bit of metal inside then a drill bit that is made to drill holes with a counter clockwise rotation would probably do the trick. i have used this trick a lot with getting out broken bolts but have never tried it with a spark plug so i'd wait on a few more replies to this before i gave it a shot.
Old Sep 13, 2010 | 01:14 PM
azlodaniel1's Avatar
azlodaniel1
I have used a bolt extractor to do this when it happened on my street bike. But that was because I over tightened the plug.
Old Sep 13, 2010 | 01:40 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Removing the head is going to be the easiest at this point. How else would you grab on to it and even if you could drill and extract it, where would all the metal shavings go?
Old Sep 13, 2010 | 02:42 PM
mexico's Avatar
mexico
drill, vacuum and spray with compressed air, remove.
just dont go all the way through the plug though.
Old Sep 13, 2010 | 03:09 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
5.9 heads must be different than our 5.7 heads
Old Sep 13, 2010 | 06:43 PM
dodgeboy1979's Avatar
dodgeboy1979
ya 5.9 are alot different, the plugs are visible down the sides of the block by the manifold. +1 on the drill but not all the way through and invest in a good extractor bit.
Old Sep 13, 2010 | 06:58 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Lol...,he'll with ours we need a few extensions just to get to our plugs
Old Oct 9, 2010 | 05:31 PM
jsmity77's Avatar
jsmity77
ive got a 5.9 with the same issue but the insulator and everything came out, now theres a hole through my plug an the only thing left is the threads and i can see into my cylynder, im probly just gona pull the head to be safe i dont wana risk knockin the little prong in the engine
Old Oct 10, 2010 | 02:12 AM
RedTruck-VA's Avatar
RedTruck-VA
I would try to extract the plug first, a magnet and vacum can get bits and pieces out. But you are the one looking at it so you will know best what needs to be done. Good luck....
