2006 ram 1500 front shock????
Old Sep 14, 2010 | 07:23 PM
crazyhorsemd's Avatar
crazyhorsemd
Default 2006 ram 1500 front shock????
Want to replace front shocks on my ram. 2006 1500 Big Horn edition, 20"wheels. want to go with Bilstein 5100's.
1. Does this have shocks or struts. Looks like coil over shocks.
2. Does anyone have part # for these (shocks or struts)
suggestions on how to go about this. do I need spring compressor?
looks like the "shock" has a U shaped piece of metal welded to the bottom bolt piece..does the Bilstein come with this already welded on?
I know..lots of ???'s but I want to order the right part
Great forum
Thanks...BA
Old Sep 14, 2010 | 07:35 PM
dirtydog's Avatar
dirtydog
Moderate User
I take it you have 2wd?
https://dodgeforum.com/forum/3rd-gen...ew-shocks.html
a whole list of all the shock threads.
https://dodgeforum.com/forum/search....archid=2274609
Old Sep 15, 2010 | 05:26 AM
crazyhorsemd
no, it's a 4WD
Old Sep 15, 2010 | 01:44 PM
[meph]'s Avatar
[meph]
yes its a coilover strut. yes the bilsteins come with everything you need. you just have to swap the coil and coil seat from the factory struts. and yes, you will need a spring compressor
http://moesperformance.com/index.php...ducts_id=12457
Old Sep 15, 2010 | 11:47 PM
bigtigga84's Avatar
bigtigga84
you trying to level the truck or just replace the shocks?
Old Sep 16, 2010 | 04:55 AM
crazyhorsemd
Thanks, and yes I want to level the front end. Thought if I get the 5100's it would level (or lift slightly) the front end.
Thanks All
Old Sep 17, 2010 | 01:10 AM
bigtigga84's Avatar
bigtigga84
they do, couple guys on here with longer trucks have them and the 5100 have leveled them nicely. don't know why mine's exactly and i mean exactly an inch higher in the rear still. but they are still awesome, love mine. i just always seem to have issues no matter what it is lol.
Old Sep 17, 2010 | 05:35 AM
crazyhorsemd
So... if I have this correct, I can gey 5100 struts for the ram 1500 2006, it comes with all I need but have to use my springs. AND, (using spring compressors) I can install them. No real big issues. I've changed shocks before,never struts, but I believe I change these also. Do I need to look out for any oddities or unusual ways to approach this to make it easier?
thanks
BA
Old Sep 17, 2010 | 12:54 PM
bigtigga84's Avatar
bigtigga84
yes to all. i took mine off and took old strut and all to a shop and had them switch the shocks. spring compressor was lookin a little sketchy.
Old Sep 18, 2010 | 10:04 AM
crazyhorsemd
Hey...Thanks for the advice..think I'll do the same and let them worry about the spring compression.
BA
