Backpressure
Old Sep 20, 2010 | 01:38 PM
ki4ppg's Avatar
ki4ppg
Default Backpressure
Does the hemi have enough backpressure from the cats that true dual straigh pipes wont cut power or mileage?
Old Sep 20, 2010 | 02:25 PM
dirtydog's Avatar
dirtydog
Moderate User
A member on here did dyno runs with and without a cut-out. He lost 3hp using the cut-out.
Running lengths of pipe out the back will increase pressure over just a cut-out after the cats.
You'll be fine. Prob couldn't notice a difference even if there was any.
Old Sep 20, 2010 | 04:05 PM
truckin151's Avatar
truckin151
I gained hp/tq with the cutout open, and lost some with it closed, but my times were slower with it open and faster when it was closed. I got the dyno sheets somewhere around here so I'll have to go see if I can find them but it was around a 10rwhp/tq increase with the cutout open vs closed.
If you are going true duals with just the cats you should be fine as long as you stick with a 2.5" pipe and dont go any bigger.
Old Sep 21, 2010 | 02:16 PM
ki4ppg's Avatar
ki4ppg
thanks just know on the chevy lost alot of low end torque
