2002 4.7l Idle and stall problem
Old Sep 23, 2010 | 11:32 AM
Nodrog1's Avatar
Nodrog1
Default 2002 4.7l Idle and stall problem
Hi, I'm new here. I have a 2002 Ram 1500, 4.7 l. It just started stalling yesterday and idles at very low speeds, 500 RPM instead of usual 625 RPM. Any ideas on how to fix would be appreciated.
Thanks
Nodrog1
Old Sep 24, 2010 | 12:29 AM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF.
Let me move this to the 3rd gen section, get you some answers.
Old Sep 24, 2010 | 12:52 AM
Pyro's Avatar
Pyro
I Beat Tetris
Clean the throttle body out, most likely you've got a bunch of crud built up and it's clogging the idle air valve.
Old Sep 24, 2010 | 06:38 AM
Nodrog1's Avatar
Nodrog1
Thanks. I removed the IAC and cleaned it and throttle body with Carburator Cleaner and it works fine now. Saved myself a couple of hundred bucks I'm sure.
Old Sep 24, 2010 | 06:54 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome. Any maintenance you can do yourself is good money saved. Have you been maintaining everything else regularly?
Old Sep 24, 2010 | 10:56 AM
Nodrog1's Avatar
Nodrog1
Hi weedahoe. No I typically take it in for service and do keep it maintained very well. I just thought this didn't seem like too difficult a task so decided to fix myself. Used to do all my own maintenance years ago before vehicles got so complicated and computerized. Kinda miss it.
Old Sep 24, 2010 | 01:43 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Its still the same for the most part, plugs, wires, air filters, oil, hoses, belts, susp part, brakes, ect. All of that and more you can still do yourself. Anything that seems too much for you we can always help out with.
