Intermittent starting issue
Old Sep 23, 2010 | 08:48 PM
02blue's Avatar
02blue
Default Intermittent starting issue
Have an 02 1500, with the 4.7. Last nite, went to start it up just kept cranking wouldnt fire. Checked fuel pump fuse,ect still would fire. Tapped on gas tank with the flashlight and it fired right up. No prob this morning, try to start after work, same issue and same fix. Not sure if its fuel pump or a loose wire somewhere? Would the fuel pump act up or just quit completely?
Old Sep 29, 2010 | 11:23 AM
popdog's Avatar
popdog
If tapping the gas tank is "fixing" the issue likely you're looking at a problematic fuel pump.
Old Sep 29, 2010 | 12:10 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Or just to think of everything, it could be the electrical harness at the top of the tank for the pump. If you are sure it is isolated to the pump then drop the pump and check the harness and contacts and try hot wiring to try to duplicate the issue
Old Sep 30, 2010 | 01:40 PM
02blue's Avatar
02blue
Turned out to be the pump was going. Issue lasted till Saturday night then the truck wouldnt start at all. Dropped the tank and put a new pump in on Sunday.
Old Sep 30, 2010 | 03:25 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Good for you and glad to see you got it resolved.
