New Muffler = Loss of Power???
Old Sep 23, 2010 | 10:59 PM
BigOrange's Avatar
BigOrange
Default New Muffler = Loss of Power???
2008 Ram w/ 4.7L
I just switched from an 18" XLerator Single 3" in, Dual 2.25" out with pipes straight out the back to a 14" Magnaflow Single 3" in, Single 3"out directly into a 3" to 2.25" Y-pipe into the existing 2.25" pipes out the back. I did this because the XLerator didn't produce the sound I was looking for. It actually made a terrible low bass drone from 1200-2200 rpm that was really annoying & really lound..... it didn't even sound like a V8!!! The problem is that I lost a noticable amount of power. The engine feels like it's working harder, and doesn't pull as much on the top end. Does this sound right for going from a 18" SI/DO to a 14" SI/SO muffler with a y-pipe? I didn't think it would make a performance difference, and the muffler guy said it would flow the same as well. Any thoughts on whats going on here? I'm also wondering if an 18" Magnaflow SI/DO would make that same deffening bass drone that the XLerator made under light ecceleration....
Also, I did unplug the battery for a while to do a computer reset, but that was 6 days ago when I had the muffler installed. Also running an Airaid Modular Intake tube to the factory airbox with a K&N drop-in filter.
Any input, thoughts, or ideas would be great here! Thanks!
Old Sep 23, 2010 | 11:43 PM
Matt99's Avatar
Matt99
I had about the same result going from straits to a si/do magnaflow
Old Sep 24, 2010 | 11:34 AM
BigOrange's Avatar
BigOrange
Were you talking about performance or sound results? Did your PCM eventually adjust to the new setup and adjust back to optimum power? Or does it still feel sluggish?
