knocking sound...?
Old Sep 28, 2010 | 07:39 PM
BIG HORN RAM MAN's Avatar
BIG HORN RAM MAN
I have an 04 that does the same thing but no other problems runs great Hemi's just tick I have had every diagnostic done that I can think of and everyone says the same thing it is just the character of the Hemi to knock so turn up the stereo.
Old Sep 29, 2010 | 12:24 AM
tony713's Avatar
tony713
i seen one of those repo style tow truck with a hemi. sounded like a 24v cummins. i asked the guy about it and he said he had the dealer replace the bottom end twice for one noise like mine and the left head for the tick noise under warranty and neither fixed it and after all the work the dealer told him it was normal.
after i heard that thing run it made me feel a little better. that was when i first got the truck.
Old Sep 29, 2010 | 07:41 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Originally Posted by tony713
its defiantly not an exhaust leak. crawled under it just now. its coming from the rear of the motor. and can really here it through the oil pan. almost sounds like timing chain slap. but with only 38k on the motor its hard to believe it went bad already.
these motors dont have a chain driven oil pump do they?
timing chain and oil pump are at the front of the engine behind the timing cover.
Old Sep 29, 2010 | 05:47 PM
tony713's Avatar
tony713
then im stumped
Old Sep 30, 2010 | 07:43 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Toner wheel on the crank is at the back of the engine. Maybe something in the windage tray is getting tapped. I guess the best thing would be to pull the oil pan and have a look
Old Sep 30, 2010 | 07:50 AM
RedTruck-VA's Avatar
RedTruck-VA
HEMI tick?
Which I don't have, but have heard is valve train related.
Old Oct 23, 2010 | 10:31 AM
desert ram's Avatar
desert ram
i have an 03 and it does the same thing, same sound. it sounds like a knock from the rear, tc,oil pan area,strange noise but has always done it.
Old Dec 28, 2010 | 09:49 PM
Ajax_6154's Avatar
Ajax_6154
my truck just started doing this same exact thing today. did you ever figure it out
Old Dec 28, 2010 | 10:35 PM
Speedaholic's Avatar
Speedaholic
Engine Rocker Noise
http://www.youtube.com/watch?v=aZU0OzhsgyQ
2002 DODGE RAM INTAKE NOISE
http://www.youtube.com/watch?v=jz1U9...eature=related
2003 Dodge Ram 3500 Knocking
http://www.youtube.com/watch?v=Da4Ej7UF-d8
I have the same sounds.
Old Dec 29, 2010 | 09:26 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Nice vids but none are HEMI related.
(first vid) 3.7/4.7 rocker issues are common as are overheating and misfiring
(second vid) again, that vid is 4.7
(third vid) is a 3500 which is likely a CTD
