HELP needed on diagnosing an issue with the stock CD radio on 2004 dodge ram 1500 qua
Old Sep 28, 2010 | 01:15 PM
kevin3vd1's Avatar
kevin3vd1
Default HELP needed on diagnosing an issue with the stock CD radio on 2004 dodge ram 1500 qua
HELP needed on diagnosing an issue with the stock CD radio on 2004 dodge ram 1500 quad cab SLT.
Turns on and sound works on occasion but cuts out alot when in cd mode or in radio mode.
***Is it a speaker issue or radio issue or computer issue?
How can I test this?
**AND Does anyone have a diagram of power/electrical system for the 2004 Dodge ram 1500 quad
cab?
Any input is greatly appreciated.
Kev
Old Sep 28, 2010 | 01:48 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Do you have the Infinity unit or not? If all sound cuts out and you do not have the Infinity system then it is the HU that needs to be replaced. If you do have the Infinity system then it could be either the amp or the HU. But it is not cost effective to replace either.
So either way, it sounds like it is time to replace the HU and get something after market that has more controls, option, flexibility and better sounds.
Old Sep 28, 2010 | 02:19 PM
kevin3vd1's Avatar
kevin3vd1
Default I have the infinity unit. What's the HU? Thanks for your help
Old Sep 28, 2010 | 02:24 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
head unit
Old Sep 28, 2010 | 03:34 PM
cwboyjohnny24's Avatar
cwboyjohnny24
Does it turn off, or does the sound quit working. I think the infinity system has an amp installed from the factory that could be going bad on it.
Either way, I would just suggest getting a better HU as weed said. Your stereo is probably just getting tired. So many aftermarket's out there that you would be even happier with. Just MHO
Old Sep 28, 2010 | 09:25 PM
kevin3vd1's Avatar
kevin3vd1
Default Is the stock Infinity CD,radio +Tape player the "SAME SIZE" as the stock CD+radio pl
Is the stock Infinity CD,radio +Tape player the "SAME SIZE" as the stock CD+radio player?
Plugs all the same for both?
I'm wanting to Replace a stock Infinity CD,Tape, radio player with the stock Infinity CD Plus radio player.
Big Thanks to you guys! I have a pic if you need to see it.
Kevin
Old Sep 28, 2010 | 09:53 PM
BadHab1t's Avatar
BadHab1t
better off getting a new hu period aftermarket has so much more to offer...
Old Sep 29, 2010 | 08:03 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
The stock HU is 1.5 DIN in size. You can find those replacements or you can go down to a 1 DIN HU that is a single slot CD player or even a fold out screen with DVD and Nav. Or I can make you a 2DIN bezel and you can use a big double DIN touch screen with DVD/Nav/BT and whatever else.
Old Oct 1, 2010 | 11:54 PM
kevin3vd1's Avatar
kevin3vd1
Default Hey! I need replacement radio for dodge ram. Saw a post on CD radios ipod compatib
Hey! I need replacement radio for dodge ram. Saw a post on CD radios ipod compatible for under a $100. Any good advise on under a hundred?
What's should a guy look for for. I have 2 ipods so that would be nice.
Just need it to be reliable.
Thanks!
Old Oct 4, 2010 | 10:35 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Under 100? Im going you need you to raise that amount a little if you want something really good. However, if you want something simple Im sure ou can find it for that. Try looking HERE
