Let's Play: Would this work?
Old Sep 28, 2010 | 03:08 PM
Smitz's Avatar
Smitz
Default Let's Play: Would this work?
Got bored this morning, so I drew this up. Just a concept.
http://imgur.com/8zP3z.jpg
Let's temporarily suspend this notion of needing:
1. Funds
2. Needing to pass smog
3. Noise regulation
4. A system to attach this to the truck.
Parts:
A. 5.7 Hemi
B. Borla XR-1 longflow Headers
C. Whatever Works
D. Quicktime Performance QTEC60CP
E. Whatever Works
F. Flowmaster 50 Series Big Block
G. Whatever Works
All with ~3.5" pipe
The benefits I see:
Cutouts closed means very quiet, yet still no major curves thus maximizing airflow with only necessary restrictions.
Cutouts open means no restriction of air flow at all. And it would probably be louder than hell with: APM automotive Ram Air, BBK 90mm Throttle Body, Fidanza Flywheel, 273 Cam etc.
Old Sep 28, 2010 | 03:17 PM
ridinghighdodgeguy's Avatar
ridinghighdodgeguy
haha nice parts! have you checked out the stuff from afe though? You might like it.
http://www.afeintakestore.com/143488...dodge-ram.html
Old Sep 28, 2010 | 03:23 PM
cwboyjohnny24's Avatar
cwboyjohnny24
You would just have to do the non-fouler trick with the 02 sensor so it doesn't throw a CEL every time you open the cutouts since it would naturally go after the cats.
You could also make your own CAI that will flow just as well as almost all on the market right now and have it flowing from where ever you want that you can pull the coldest air.
Other than that, I'm sure some other people will chime in with their ideas.
Old Sep 28, 2010 | 03:43 PM
Smitz's Avatar
Smitz
the reason I chose that ram air is because they are the first group to (in my mind) do it correctly. You have a hood scoop, take air from that hood scoop and with as few bends as possible, cram it down the throat of the engine as directly as possible. Possibly with an air filter.
The other "ram air" SRT-10 hoods that I see want to take this nice 180 degree vacation where air can stop and have a mai tai in the air filter. Only when more air shows up it will consider getting to the airbox.
Old Sep 28, 2010 | 03:50 PM
cwboyjohnny24
I dunno. Looks like a good idea, but I still see some hella bends in the tube there. Especially the bend it has to make to go back to the TB. I'd just have to replace the rubber tube with a plastic or even sh!tter pipe to smooth out the air flow going on there.
Matt99's Avatar
Matt99
i dont know about 3.5 in pipe because thats going to be a damn high flowing system, I know that I had straits and didnt have enough backpressure and you could feel it from takeoff
Old Sep 28, 2010 | 03:53 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Well on mine Ive got Pacesetter LTs, no cats, x-pipe, dual DMH cutouts, dual 4" round Magnaflows and dual 4" tips.
Does it sound great? I think so and I love it but its not a cheap setup
Old Sep 28, 2010 | 03:55 PM
eric41191's Avatar
eric41191
3.5 would be too big of a pipe for this i think. If your going to run true duals you can do 2 3/4 pipe, which i know from experience gives a nasty sound with a cut off. What brand cut off are you looking to use?
Old Sep 28, 2010 | 04:01 PM
cwboyjohnny24
Also, I would hope that on the ram air setup they have something to prevent water from flowing directly in. I know they have a mesh setup for the insert, but if you get a heavy rain and water directly flowing into your intake would be a bad thing IMO.
Hopefully you don't do off roading or a rock landing on it or anything like that since a fiberglass hood would be pretty easy to crack I would think.
Old Sep 28, 2010 | 04:03 PM
glass3222's Avatar
glass3222
It seems ok, but you have a few problems in my opinion:
A. 5.7 Hemi good
B. Borla XR-1 longflow Headers not made for hemi or dodge ram. I would go with pacesetter LTs
C. Whatever Works not needed, that cutout has a Y included
D. Quicktime Performance QTEC60CP ok
E. Whatever Works Magnaflow cats are good
F. Flowmaster 50 Series Big Block FM suck IMO. Go with magnaflow or Borla XR1
G. Whatever Works
All with ~3.5" pipe to large unless you have some serious head work to increase the flow.
You are also missing an H or X pipe, that will balance the flow and maintain the velocity needed for scavenging.
I would also say 90mm TB is a waste unless you have forced induction and a different intake. The truck plastic intake that the TB bolts to only has an 85mm opening.
