Whirring noise that matches rpm's???
Old Sep 28, 2010 | 09:51 PM
Bent's Avatar
Bent
Default Whirring noise that matches rpm's???
What is likely to go on me first, the waterpump, or the P.S. pump?
I have a whirring sound that follows engine rpm - I don't like it because I can hear it over the "Hemi Tick". I suspect it's one of the above.
I have just a shade under 100 000 miles on my '04.
Old Sep 28, 2010 | 10:54 PM
traker1001's Avatar
traker1001
Neither make a whirring noise when they go bad. But the water pump is usually more likely to go first.
Old Sep 28, 2010 | 11:53 PM
JAWalker21's Avatar
JAWalker21
Is it a whir or a whine? Could be a the alternator as well. Mine sounds like a supercharger whine. Waiting on the new one to come in so I can put it on.
Old Sep 29, 2010 | 07:10 AM
Bent's Avatar
Bent
not high enough pitch to be considered a whine...
I don't know what a supercharger sounds like, 'cause the only blowers I've had any experience were those on Detroit s-stroke diesels.
Maybe I'm just hearing a bearing in the serpentine belt pully system starting to cack.
I'll locate a stethoscope and find the source.
Old Sep 29, 2010 | 07:49 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Could be pinion bearings or gear whine also unless you are sure it is coming from the engine.
Old Sep 29, 2010 | 08:41 AM
nateroach's Avatar
nateroach
I agree with Weed. Does it whine in park, or only when in gear and moving? If it is while your in gear and moving I would be looking at the drivetrain (gears, bearings, wheel hubs etc.) if it whines in park/neutral my first thought would be alt, but clearly it would be something attached to the accessory drive.
nateroach
Old Sep 29, 2010 | 10:22 AM
Bent's Avatar
Bent
it whirrs when in park/neutral too
Denniss66's Avatar
Denniss66
my truck sounds like a supercharger whine. i got my alternator rebuilt and i still got the wine i was at a shop the other day and the guy said it sounds like its coming from the power steering pump.
Old Sep 29, 2010 | 10:41 AM
nussdawg395's Avatar
nussdawg395
Thats my guess is an alternator.
Old Sep 29, 2010 | 11:11 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Agreed. Sounds like a engine accessory. As someone said earlier, an automotive stethoscope would help and work best here
