will 37x13.5r17 fit on 08 ram 1500 quad cab 4x4 6" pro comp
Old Sep 29, 2010 | 02:15 PM
HammerZ71's Avatar
HammerZ71
Originally Posted by hemiman07
I have a Fabtech 6 inch lift and it is actually about 4 1/2 inches. I have Pro Comp 35x 12.5x20's and they are actually about 32 inches tall. So every manufacture can be different. I do a little off roading and my tires will rub a bit so I try and not to turn it lock to lock, or keep out of deep ruts.
That's why I like my Rancho lift. It's a 4" lift and I actually cranked my key bolts DOWN a smidge for exactly 4". I feel I could crank them up maybe 1"-1.5" over stock and add 1" blocks in the back to clear 37s if I wanted to.
MANY of the 6" kits for torsion fronts are between 4.5" and 5" and want you to crank the key bolts up for the difference which IMO is a TERRIBLE thing to do as it significantly weakens the CVs.
And like I said, I have yet to see a tire that is actually at it's rated height as well. Some ain't even close...
Old Sep 29, 2010 | 04:10 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
my 36's are 13.50 but my tires are about 1/4" away from the spindles.
Old Sep 30, 2010 | 09:01 PM
minime_0616's Avatar
minime_0616
what kind of 36X13.5 r u running?
