Removing Valve body from tranny
Old Sep 30, 2010 | 03:55 PM
sinus19's Avatar
sinus19
Default Removing Valve body from tranny
so im going to be replacing the Gov Pressure solenoid, Gov pressure sensor, and overdrive & lockup solenoid. since my trany keeps going in and out of limp mode out when it feels like it, it has already thrown the Gov Pressure solenoid code. so i figured that it would be best to replace all three, anyways, i know that the wire harness for the overdrive & lockup solenoid goes up into the valve body and my concern is that I have never taken out the valve body. I also know that i dont have to disconect the wires from inside the VB but i rather do it so it has new wires as well. So what should i look for when taking it down? is there anything that will fall out and that i need to be carefull with? Thanks in anvance.
Old Sep 30, 2010 | 04:03 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
See if OldDirtyJohn can help you out with this one. PM him
Old Sep 30, 2010 | 04:05 PM
sinus19's Avatar
sinus19
ok, thanks
Old Sep 30, 2010 | 04:53 PM
SLT8's Avatar
SLT8
He did a detailed write up but i dont have the bookmark at work though to post it.
Old Dec 13, 2014 | 10:17 PM
labreapits's Avatar
labreapits
I realize this is an old post, but do you still have a bookmark to the write up?
