Place to order e-fan relay?
Old Oct 2, 2010 | 03:07 PM
freestyledude's Avatar
freestyledude
Default Place to order e-fan relay?
Need a relay to run my e-fan, its a two-wire taurus fan. Not sure on amperage but I do know it pulls a bit more air than the 3 wire fan on high. I was thinking 80 amp relay to be safe?
Main question - Where can I order online a heavy duty relay and socket? Local auto parts stores are useless, highest they can get is 40 amps
Old Oct 2, 2010 | 04:31 PM
chambers's Avatar
chambers
http://order.waytekwire.com/productd...POWER%20RELAY/, this is where I got the one I use for my taurus fan which I run on high. You can also get larger relays like it on ebay.
Old Oct 2, 2010 | 09:36 PM
BadHab1t's Avatar
BadHab1t
ebay or stereo shop, im using a 40 amp from aap and it works fine...
Old Oct 3, 2010 | 04:02 PM
nussdawg395's Avatar
nussdawg395
You can get one from almost any auto parts store. I got a hayden controller from autozone for $35.
Old Oct 4, 2010 | 10:05 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Auto part stores do not carry big relays and those that come with the Hayden usually are only 40 amp relays.
I replaced the relay on my Hayden controller with a 80/60amp relay from ebay for $11-12
Here is the link and the item number is 110373059322
The pins do have to be trimmed to fit the controller. They are bigger to carry the extra current and load.
http://cgi.ebay.com/60-80-AMP-RELAY-...item19b2bf3afa
Old Oct 4, 2010 | 06:58 PM
freestyledude
okay thanks guys! Local stores are always a pain to deal with, selection in Canada is terrible for anything related to auto repair. What connectors should I use to hook up the relay?
Old Oct 5, 2010 | 08:21 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You will need a fan controller like an Hayden 3647 which the relay will fit into.
Old Oct 5, 2010 | 08:34 PM
freestyledude
I have the flex-a-lite controller that doesn't have a plug-in for a relay
Old Oct 6, 2010 | 07:31 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Does it have a relay on-board already?
Old Oct 6, 2010 | 06:32 PM
freestyledude
No, because in the catalogue there was a relay included with the full kit, but was not heavy enough for my fan. I just bought the sensor, which had a controller, and a probe
