Front drive shaft removal questions?
Old Oct 3, 2010 | 09:59 PM
stenerson's Avatar
stenerson
Default Front drive shaft removal questions?
2004 Dodge Ram 1500 slt 4x4. I was under the truck today and noticed a torn boot on front drive shaft. The driveshaft seems to come in 2 pieces. There's a boot at the transfer case end with 2 clamps. This ones fine. Then there's another one about halfway up where another shaft begins. (not sure how to describe). 2 dumb questions since the Chilton manual gives no info. Can I remove the whole setup and drive it without hurting anything while I fix this? (assuming of course I don't use 4x4). 2nd question chilton manual doesn't describe this at all and I want to do it right. Any online helpful tutorials? I been googling no luck.
Old Oct 3, 2010 | 10:07 PM
Marklorenzo's Avatar
Marklorenzo
Welcome to my world bud I just got out to my grandpas garage about two hours ago all happy to get the nobby tires rotated and so some underbody painting, and bam I took off the front left tire and the boot is busted. This has been my second boot I am going to replace. I was just getting ready to post a thread asking for some help. You will need a 36 mm socket.
http://www.kmperformance.com/techcen...halfshaft.html
Old Oct 3, 2010 | 10:11 PM
Marklorenzo
pull the wheel, then the brakes. pull the upper control arm off and the steering tie rod as well. Then you should be able to get to the boot.
Old Oct 3, 2010 | 10:14 PM
stenerson's Avatar
stenerson
Mine is the drive shaft that goes from transfer case to front differential.
Old Oct 3, 2010 | 10:41 PM
stenerson's Avatar
stenerson
I just found an online image that shows what I'm talking about.
Old Oct 3, 2010 | 10:51 PM
Marklorenzo
Im sorry I misread.
Old May 10, 2017 | 12:48 AM
raygray1983's Avatar
raygray1983
I have a 02 Dodge Ram 1500 Slt, Im trying to get the front dive shaft out and im having some trouble. So ive got the four bolts out and it is off the front diff, and the clamps off the boot, but the excaust is right below the front of the drive shaft ant i have no room to pull it from the transfer. Any suggestions?
Old May 10, 2017 | 12:53 AM
raygray1983
Old May 10, 2017 | 08:09 AM
TrueDogman's Avatar
TrueDogman
If my memory is right the front of the drive shaft goes up kinda above the front diff then slid forward and out of the transfer case then moved rearward to remove.
Old May 12, 2017 | 11:25 PM
dodge it then ram it's Avatar
dogman is right. after you unbolt the front end of the shaft, raise it up then forward beside the exhaust manifold. That should give you enough room to drop the other end down then pull it out.
