I need help. no speedo and a bunch of lights on
Old Nov 10, 2010 | 05:29 PM
  #21
reddodge12's Avatar
reddodge12
anyone else help me out?
Old Nov 10, 2010 | 06:12 PM
  #22
dirtydog's Avatar
dirtydog
Moderate User
Well p0500 is the speed sensor as you already know. Did you check the front sensors within the hub assemblies?
Old Nov 10, 2010 | 07:07 PM
  #23
reddodge12's Avatar
reddodge12
I do not have any front wheel sensors, it does not have ABS sensors
Old Nov 11, 2010 | 08:45 AM
  #24
weedahoe's Avatar
weedahoe
Hall of Fame Member
Originally Posted by reddodge12
i just used my DVOM and i got 12.3 volts off and 14.02 running, still think think it could be the battery?
It could still be the battery. The charging voltage of the alt has little to do with the charging capabilities of the battery or its amp load rating when dying. All you showed there was that the alt is putting out voltage.
Old Nov 11, 2010 | 10:07 AM
  #25
elite1msmith's Avatar
elite1msmith
I can't even get the codes using the ignition, is there a trick or someone, can I not be in the drivers seat? Is the on,off,on,off,on. Correct, . Fast? Slow?
Old Nov 11, 2010 | 05:24 PM
  #26
reddodge12's Avatar
reddodge12
what codes are you trying to get?
Old Nov 12, 2010 | 07:01 AM
  #27
weedahoe's Avatar
weedahoe
Hall of Fame Member
He is trying for the DTC codes I assume. There is a How To in the FAQs that are stickied at the top of this forum section. But they are not DTC codes per se. IMO, you should go by any auto parts store and let them connect a scanner to the truck and give you the codes.
Old Nov 12, 2010 | 09:32 AM
  #28
dirtydog's Avatar
dirtydog
Moderate User
Since you stated in your original post that your ABS light is illimunated, it's rare, but can happen, that you have an illuminated ABS light without ABS on your vehicle. Most Rams have RWAL(rear wheel abs). if you didn't have abs at all, then your cluster would not illuminate ABS and should have been diabled by the manufacturer upon programming.
The abs module for the RWAL is between the battery and the firewall on the driverside fender. I'm not sure if the speed sensor wires go into that and then to your ecu??? I haven't paid attention??
Old Nov 12, 2010 | 09:52 AM
  #29
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
is it possible the alternator crapped out because it was struggling with keeping a dying battery going?
Old Nov 13, 2010 | 07:40 PM
  #30
reddodge12's Avatar
reddodge12
alternator tested good.
