How to recalibrate throttle
Old 10-04-2010, 10:30 PM
vincent714028's Avatar
vincent714028
vincent714028 is offline
Default How to recalibrate throttle
I have an 04 ram 1500 5.7 and I'm trying to re-calibrate my throttle. I've reset the pcm but that didn't do it. Can someone give me the procedure?
Old 10-04-2010, 11:00 PM
That1guy's Avatar
That1guy
That1guy is offline
I'm pretty sure you turn the key to on but dont start it. Then slowly push the pedal to the floor. While holding turn the key off then slowly let out.
Old 10-04-2010, 11:31 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
Old 10-05-2010, 08:13 AM
FrostKing's Avatar
FrostKing
FrostKing is offline
It clearly states in the service manual that this procedure is for diesel trucks only. For the Hemi you simply turn the key on and wait 10 seconds before starting. This is the biggest myth about our trucks that keeps recirculating over and over.
Old 10-05-2010, 08:42 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Oddly enough, I just went though the 04 Srvc Man and couldnt find anything on calibrating the APPS other than on a CTD? Can anyone provide anything in the manual for a gasser on this? I may have missed it.
Old 10-05-2010, 02:20 PM
HammerZ71's Avatar
HammerZ71
I will have to try it when I get home this evening. I will say that a buddy of mine tried it on his '06 Hemi and it beeped like it was supposed to. I'd say if it didn't work on his truck, he wouldn't have gotten the "beep" response, no?
Old 10-05-2010, 03:07 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Dodge Forum Moderator
First off. Why are you trying to recalibrate? What is the issue? It may be that your T/B is no good! Please answer questions.
As far as re-calibration, it is correct that you only need to turn the ignition to the run position and NOT start. It learns itself automatically. No pressing the pedal is needed.
Hammer, the dinging your buddy prob got was when he reset the oil light...lol?? It will ding after the pedal is pressed 3 times to alert the driver that the oil light has been reset.
Old 10-06-2010, 02:12 PM
vincent714028
I put the superchip 3865 tuner on my truck and am currently adjusting shift points to get it how I like. In the data logging menu both the throttle position sensor display and accelerator position sensor display show 5% to 10% when I don't have my foot anywhere near the pedal. Since my in-town driving is very light throttle anyway I don't want this to cause incorrect shifting at light throttle.
So far I've tried turning the key to on position without starting and slowly pushing in and letting out the pedal to reset it. If I only have to turn key to on position without depressing pedal as you say, dirtydog, then that may indicate that my sensors are bad. I will check my data log tonight to see if there has been any change.
I can answer any question you want. Yours was the first question.
Old 10-06-2010, 03:16 PM
FrostKing's Avatar
FrostKing
Both APPS and TPS have redundant sensors in them to ensure safety and accuracy of the drive-by-wire system. If there are any discrepancies then limp-mode is immediate. I believe the TPS is also measured in degrees (90* = wide open) and is mis-interpretted as %. The small % you are reading is the minimum position of the throttle-body and pedal. You can force them to 0 by hand, but are spring loaded to open slightly.
Old 10-06-2010, 11:24 PM
vincent714028
Great point. That makes complete sense.
Quick Reply: How to recalibrate throttle
